unconfigure upm timer
unconfigure upm timer timer-name profile profile-name
Description
Removes a UPM profile from a UPM timer.
Syntax Description
timer-name Unconfigures the specified UPM timer and deactivates any running timer.
profile-name Removes the specified profile from the UPM timer.
Default
N/A.
Usage Guidelines
Use this command to unconfigure a timer setting. This command does not delete the timer.
The specified timer is stopped by this command, even if it has been activated.
This command was first available in ExtremeXOS 11.6.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the Universal Port feature, see the Switch Engine v33.1.1 Licensing Guide document.
